error... No Amplifier connected
Hi for some weeks I have a problem with the red board
I see a error  No Amplifier connected
I have test this with 2 antennas and also with 2 amp boards
All with 2 different  ferrite antenna
1 on the roof  and for this moment 1 into this room
The firmware version I have is now 8.0
But also with the 7.4 version I have the same problem
Ware can I look for fix this problem ?
Greetings  Gert
[Image: no_amp.jpg]
Stations: 127, 1845, 3108
Does the LEDs on the amp turn on?
Stations: 733, 1440, 2601
(2016-09-04, 20:08)DelandeC Wrote: Does the LEDs on the amp turn on?
Only the Red led is on  if I see the error  No Amplifier connected
Green and Yellow are off
now the amp is turning on by him self ?  and I see blinking the  4 Yellow led  and also the Green led is now on and also the Red
its very strange but the amp is turning off and on by him self
Did you try a other cable?
(2016-09-05, 04:56)DelandeC Wrote: Did you try a other cable?
Yes  I  have
Now I see into the screen from the board  a new error
I see now  into the SYS option   Vin Too low !
don't know if this normal ?
(2016-09-05, 17:55)Rothuize Wrote: Now I see into the screen from the board  a new error
No this is not normal, it is telling you that your power supply is faulty or underpowered.
Try a different power supply that can supply 5 to 5.3V at a minimum of 2A.
Ben.
Stations: 878
Ben.
Thanks Ben
Only I do not have a extra power supply for this moment
for now I have it into the USB from the computer .. and I know this will not by a good idea,,  but its for this moment working  4.9V
I do have a power supply for the iphone but I think this will by also not a good idea
I will look tomorrow for a power supply
maybe this is also the problem with the Amplifier  to low power  and the Amplifier turns off ??
for this moment I run the board with 2 Amplifiers  2x ferrite antennas  now I hope all will by work ok again
thanks for this info
greetings  Gert
Try the PS for your iPhone
Maybe you have meassured 4,9 with a voltmeter, but it don't tell you how noisy it is Smile
/Richo
