Access to digitized data
Maybe a stupid question, but is there a way to access the raw digitized data? The analog data can be accessed via the optional SMA connectors, but what about the digital signal? I am looking for an easy way to check the spectrum for noise sources.
(2017-05-16, 12:11)pasense Wrote: Maybe a stupid question, but is there a way to access the raw digitized data? The analog data can be accessed via the optional SMA connectors, but what about the digital signal? I am looking for an easy way to check the spectrum for noise sources.
Not a stupid question!
You can view signal FFT on your Operator's pageĀ at Blitzortung.org, or on Lightningmaps.org...
Many of use that to initially begin a disturber track...
What's your station number and location?
Stations: 689, 791, 1439
Board was just soldered on Saturday and I am still trying to learn how to operate it. Station 1836, currently in Germany, but to be moved to Cabary islands in late June. Only the E-field antenna is any good so far, ignore the H field. The station is producing mostly noise signals.
