	Threads: 1
		2020-06-12, 06:12
(This post was last modified: 2020-06-13, 07:42 by Eric.Wouters.
 Edit Reason: take out links
		When open directory "Index of /Compendium/Hardware/PCB_20_7/" , we see same file                               05-Mar-2020 15:35              94992
                        05-Mar-2020 15:35              94992 .   If I uderstand right this files must be different.
	Threads: 35
		Hi aeromash,
you are right 16_2 should be the E-field pre-amp with just one channel. Refer to HW 20_6.
Please remove the links to the internal documents from the public forum.
Thanks
Klaus
	Threads: 55
		 (2020-06-12, 06:12)aeromash Wrote:  When open directory "Index of /Compendium/Hardware/PCB_20_7/" , we see same file                               05-Mar-2020 15:35              94992
Yes, you are right.
	Threads: 0
		 (2020-06-13, 04:19)gerbold Wrote:  Hi aeromash,
Thanks
Klaus
But the link to the schematics is already public on the main website.
Look in the section:
https://www.blitzortung.org/en/cover_your_area.php
Then follow the link to 'Assembly Instructions System Blue'.  In section 2.2 the link is right there.
