Threads: 2
2015-03-04, 06:53
(This post was last modified: 2015-03-04, 06:53 by Gregory_J.)
Hello
Station layer on blitzortung maps is not working. There is not showing stations on map.
This is message for moderators of developers.
Best Regards
Threads: 64
(2015-03-04, 06:53)Gregory_J Wrote: Hello
Best Regards
Hi Gregory...
I checked Lightningmaps.org, and Blitzortung.org for the 'real time' displays and the detecting stations layer seems to be working fine. Were those the maps you're speaking of?
There are times as they update the server programs that there are issues, and a layer does not work properly... perhaps that was the case?
Threads: 2
Maybe it was those reason, because today ( 5 march 2015) stations are working.
Best Regards
Threads: 78
At least on Lightningmaps.org, there was a minor issue due a change in behaviour of the Google Maps API.
Threads: 2
2015-03-10, 06:13
(This post was last modified: 2015-03-10, 06:14 by Gregory_J.)
If I can still pull subject of stations layer what means colors of stations
green - working
grey - offline I think
yellow -
red -
