GPS not working on system Blue board( running 9.2)
Hello fellow Lighting enthusiasts. A few months ago I was invited to purchase a System Blue. I went ahead and ordered it. I purchased the board( of course Big Grin  The case and two ferrite cores. I will admit it took me a few months to assemble the device.
I have it all together and after firing it up, I noticed the blue LED GPS light is not lighting at all. When I do a reset/ boot it will come on for s brief second so we know the circuit is goo. After that, I get no GPS either showing on the hardware case or in the GUI. All I get I sent the red text and the word word null. I did upgrade the firmware to the latest, replaced the gps antenna and even went as far as replacing the  SMA  connectors. Still nothing.
I’m looking for some advice to troubleshoot next. Can anyone chime in and let me know you’re thoughts? Thanks a ton!
Paul E.
Blaine, Minnesota. Station 2425
(2019-04-24, 21:01)Edgeminnesota Wrote: Hello fellow Lighting enthusiasts. A few months ago I was invited to purchase a System Blue. I went ahead and ordered it. I purchased the board( of course Big Grin  The case and two ferrite cores. I will admit it took me a few months to assemble the device.
Paul E.
Paul, check your email.
Regards
[Image: NOAARADlogoTXT80.png][Image: forfaviconTXT.png]
Stations: 2100
Hi Dupreezd,
I didn’t see an email from you. Could you please resend it?   Thanks Paul
(2019-04-28, 04:31)Edgeminnesota Wrote: Hi Dupreezd,
Paul, I've sent you a PM. Please let me know if you got it.
Stations: 2100
Perhaps you have already solved the problem, but I have had a similar issue. In my case the system blue had been working for over a year when the GPS antenna quit. Since the antenna is subject to harsh weather, I figured it had simply failed. However, when I replaced it, it did not work and I got a buffer overrun for the GPS in the system error log. What fixed the problem was initializing the GPS. This is listed under the tab "Tools">"GPS" in the Controller settings. Worth giving it a try if you are still having the problem.
Best Regards,
Anthony Catalano
www.boulderwx.com
acatalano@techagroup.com
Stations: 1965
(2019-06-11, 14:31)Anthony,I tried initializing the GPS and still no luck..the error i get is : availability 99.88%type:unknown ,57600 baudstatus: ! Did not get valid data from gps for 52m,23s.    PPS Accuracy: ! No valid 1PPS pulse for 53m, 35sany other thoughts? Can’t be a bad GPS antenna as this is the third one I have tried.i really like to get this up and running as quickly as possible. Wrote: Perhaps you have already solved the problem, but I have had a similar issue. In my case the system blue had been working for over a year when the GPS antenna quit. Since the antenna is subject to harsh weather, I figured it had simply failed. However, when I replaced it, it did not work and I got a buffer overrun for the GPS in the system error log. What fixed the problem was initializing the GPS. This is listed under the tab "Tools">"GPS" in the Controller settings. Worth giving it a try if you are still having the problem.
Best Regards,
Anthony Catalano
www.boulderwx.com
Possibly Related Threads...
  System Blue Not Working tferoli 10 15,083 2016-09-29, 11:30
Last Post: DnH2016
  Noise spikes on board, System Blue Jorgeminator 8 15,174 2016-06-17, 09:11
Last Post: RichoAnd
