Changing Username
Hi All, Hi Egon
It's possible to Change my Blitzortung.org Username?
Thank you
Best Regards from Switzerland
Dominic
(2021-03-15, 16:44)uwbeinternational Wrote: Hi All, Hi Egon
Thank you
Dominic
Not as a 'registered forum member'. Station Operator number and user name credential for the system servers are established when you  place your station online. Once an operator, then for this forum your status can be upgraded to 'participant', and you can make changes to your forum profile.  You 'station' operater user name and user number for the system cannot be changed once established.
I also want to change mine
Question Changing the "Home" location of the Blue Dot. BassManDanny 5 19,854 2019-11-22, 07:57
Last Post: cindyrowe
