Threads: 2
Hi!
My station is connected to GPS and syncronized, but the RTC, and GPS clok say that it's 2003. How do I fix this?
Thanks!
73,
Dennis
Threads: 63
2023-01-09, 01:16
(This post was last modified: 2023-01-09, 01:21 by cutty.)
(2023-01-09, 00:09)dhitzigrath Wrote: Hi!
Thanks!
73,
Dennis
Always helps if you include your station number and user id number, so we can validate and upgrade your forum permissions!
https://forum.blitzortung.org/showthread.php?tid=3648
and
https://forum.blitzortung.org/showthread.php?tid=2456
answer your questions.
...if you have not updated firmware to 9.4 do so. It will NOT fix the
RED controller clocks, but system
RED GPS module firmware can be separately upgraded to later version.
Threads: 2
Hi!
Station number is 2157.
Please let me access the links for the solution!
It’s a system blue, and it does have the latest firmware.
Thanks!
Threads: 78
Hi Dennis,
seems you have firmware 9.4 running now. The year 2003 is "normal", because it's a bug in the GPS module. It is possible to update the firmware of the GPS module. Instructions can be found here:
Our next firmware of the controller will correct the date, but that's just a workaround.
Tobi
