System Blue
Hi! I'm a new user, and I have a System Blue with PCB 19.5 and firmware 9.4. When I switch it on (with only power attached to the gadget), it emits a shorter higher-frequency beep and a longer lower-frequency sound. The Power, Mode, Network, and GPS LEDs illuminate for around 15 seconds before the two beeps sound again, and the entire process repeats: two beeps and lights on. I've already tried flashing versions 9.4, 9.5b1, 10.0b1, and 10.0b2, and the only difference is in the beeps. I also tried connecting the System Blue to my local network and using Fing to retrieve the IP address, but had no luck. However, when I connect it directly to my PC via Ethernet, I use Wireshark to obtain the IP address, and I can ping it but cannot access its web interface Subway Surfers. What can I do to address this problem?
As there has been a hidden link in your post which looks like spam I've closed this thread as we can not rule out that it is generated by AI. If you are a real person with a station then first try a current firmware (see documentation) and if that still doesn't work contact us via mail.
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 715 2025-04-19, 23:25
Last Post: DrFX
