Blitzortung question
This morning I am sitting here watching the realtime lightningmaps.org screen covering most of the USA and Europe and noticed something that I've seen previously. I see many lightning strikes here in the US being detected by numerous European BO stations. The display shows the detecting stations and the connecting lines to the point of the strike. My question is why are the European stations detecting lightning all over the world while most of the US stations are only reporting lightning within the western hemisphere?
See the attached map and you'll immediately notice the high concentration of lines coming from Europe for strikes totally out of the range that I would expect to see. Is this a station setup issue or server algorithm that allows strike detection to show so far away from the detecting station?
Powerful lightning produce sferics that can easily detected thousands of kilometers away. The TOA algorithm of Lightningmaps.org doesn't have any parameters regarding different regions. For historical reasons the density of stations in Europe is much higher than in other regions, so weaker lightning strokes can be detected there which can not be received by the stations in USA anymore.
Quote:Powerful lightning produce sferics that can easily detected thousands of kilometers away. The TOA algorithm of Lightningmaps.org doesn't have any parameters regarding different regions. For historical reasons the density of stations in Europe is much higher than in other regions, so weaker lightning strokes can be detected there which can not be received by the stations in USA anymore. geometry dash lite
Thanks for your answer. I got it.
  Question about Blitzortung lightning detector integration melissasmith 0 9,635 2024-05-08, 08:03
Last Post: melissasmith
