MyBo it doesn't work in PHP8
Hello, I would also like some advice. I run the website: http://www.burkovyradar.sk I use the MyBlitzortung project. It has already been resolved. The website runs under PHP7.4. However, the hosting operator requires at least PHP8. The problem is that it no longer works under PHP8.0. Can you please help her with this? Thank you. The content cannot be displayed because you do not have authorisation to view this content.
Stations: 1807, 3001
Regretfully, let me quote from My Blitzortung:
Quote:There is no more active development on MyBlitzortung by me (Tobias), but maybe by others! You can still use it, but I can not provide support. Additionally you now need an API key to use Google Maps!
Additionally, you may find that the Databases on Lightningmaps.org related to My Blitzortung, may NOT sync with data from the main BLITZORTUNG.org computing servers, and be unreliable.  Tobias has updates 'on hold' while Blitzortung refines it's regional, for example, and quality signal processing.
  lightningmaps.org doesnt work on Chrome Tested 3 40,420 2016-07-11, 20:17
Last Post: Tested
  Website doesn't save region when I return Dale.Reid 2 28,405 2014-12-11, 20:17
Last Post: Dale.Reid
