System Blue H-field only
Hi, I recently received my system blue detector, and I was trying to get it up and running with the simplest antenna configuration.  I think that is a meter long wire to use as an E-Field antenna, correct?  But upon closer inspection, the rev of System Blue that I have only has a connection for the H-Field preamp connection.  Is it not possible to connect an E-field antenna?
I think you've got one of these, then:
https://docs.lightningmaps.org/hardware/...tors/mini/
You're right, there's no E-field input on the little pre-amp board for System Blue Basic.
I have a system blue mini, and I made two air core loop antenna, as described in this document:
https://www.blitzortung.org/Compendium/D...tennas.pdf
"Multi Turn.:
20 turn, Ø38cm (38cm diameter) ~ Area ~ 0.19² * Pi * 20 ~ 2,3m² (inductance ~ 500μH)
Use 1mm² lacquer or plastic insulated copper"
Works well enough.
D
Yes! Thank you. This is all the information I needed.
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 50,216 2025-04-19, 23:25
Last Post: DrFX
Photo Turn-key System Red For Sale - H-Field and E-Field - SOLD Donald.Froula 2 19,611 2021-09-24, 16:06
Last Post: Donald.Froula
  System Blue - H-field pre-amplifier davidbonnici1984 4 33,667 2019-08-21, 19:13
Last Post: dupreezd
