user name = stuiow
station number = 2821
region = Europe (UK)
Another one:
Forum name jonfear
Station number 2831
Region UK, Europe.
User Name for Forum : Gruff 1973
Station Number if you have one: None allocated, 3900-3D00-1551-3833-3036-3138
Region... (Europe, Asia, etc...) : europe, UK
Specify specific... don't enter a lot of comments... just the facts, please....
'station not listed': Not Listed
Forum operator status not upgraded,: Not Upgraded
Station Number NOT associated with my User ID...: yes, not associated
THanks for any help you can give
(2020-10-17, 23:19)Gruff1973 Wrote: User Name for Forum : Gruff 1973
If the Staton does not have a number, then it has not yet connected to the server on the Internet. The station must be connected to the Internet, otherwise it won't work. Since you were able to read out the processor ID, I assume that the station can be reached in the local network.
So, the station is now up & running although I'm not 100% sure what fixed it!  THe only change that I made was to set the noted IP address of the controller to the IP that it had been handed out by DHCP, for some reason the address noted in the GUI was for another piece of kit on my home network - it may have been an IP clash perhaps...
In any case, it's working now & I'm delighted!  Much work to be done in dealing with interference and fine tuning the antenna positions now!
User: sm7ugo
Station Number 2737
Region: Europe
Hi, is this post still being monitored?
(2020-10-21, 18:59)SGJones Wrote: Hi, is this post still being monitored?
Your status is already changed to Participant.
Ok. Thanks.
I still get “station ID not recognised” when I try to enter it on the web page, and I can’t see it on the station list.
Maybe I need to understand more.....?
User name: yVega
User number: 2207
Station number: ?
Region: Europe
I'm online now, how can I get the associated station number?
[Image: 4178719.png]2855
Stations: 2855
(2020-10-31, 12:46)yVega Wrote: User name: yVega
User number: 2207
Station number: ?
Region: Europe
Have you registered your station on the owner's page?  If in fact your station has sent signals to the server, it should be recognized, and on your controller page, upper right, should show a number, or instruction link to register.  under 'tracker' status, should show a server connection and address.... the system WILL not recognize you IF YOU HAVE NOT sent signals.
User number: 2207
Station number: ?
Region: Europe
Have you registered your station on the owner's page?  If in fact your station has sent signals to the server, it should be recognized, and on your controller page, upper right, should show a number, or instruction link to register.  under 'tracker' status, should show a server connection and address.... the system WILL not recognize you IF YOU HAVE NOT sent signals.  AND and the system WON'T become active at all unless good GPS is noted, and 1PPS signal syncs.
User number: 2207
Station number: ?
Region: Europe
Sorry, I had activated the system with network/gps online only...
where I can read the Processor-ID for insert then in owner page?
and where can I read the sequences of operations I have to do?
I would not forget anything else
Stations: 2855
(2020-10-31, 14:52)yVega Wrote: where I can read the Processor-ID for insert then in owner page?
Please see https://forum.blitzortung.org/showthread...d#pid20250
Ok, thanks for your patient, it's all associated now.. tomorrow I'll position better primary antenna and gps antenna
Stations: 2855
yVega, what is your station number so we can have a look at it and move you to Participant status if you are sending signals.
Sorry, I'm updating request:
User name: yVega
User number: 2207
Station number: 2855
Region: Europe
Stations: 2855
User Name: Dave:WD7K
User Number: 1780
Station Number: 2283
Region: North America
Station listed, Was receiving data. No longer receiving data.
You won't need to insert processor ID... if you have sent signals, and server has activated your station, the server knows it already, assuming it is associated with your user ID.  What you WILL have to do is input the correct antenna configuration, and, if you want it's data displayed on maps, etc, make sure "ANON" is "NO"...
You probably won't need to insert processor ID... unless you've taken over a station previously assigned to someone else,... if you have sent signals, and server has activated your station, the server knows it already, assuming it is associated with your user ID.  What you WILL have to do is input the correct antenna configuration, and, if you want its data displayed on maps, etc, make sure "ANON" is "NO"...
  Station List not showing any United Kingdom stations dgoadby 2 31,794 2019-04-15, 16:35
Last Post: dgoadby
  Removing Station 723 from list Ian.Cooke 5 53,798 2015-02-03, 20:39
Last Post: Toxic
