2025-12-26, 21:47
Where do I configure the city and country settings on my receiver?
Thank you very much!
Receiver situation
2025-12-26, 21:47
Where do I configure the city and country settings on my receiver? Thank you very much!
https://www.blitzortung.org/login.php
You can update your personal info here. NOTE: "Anonyn" means exactly that. IF you 'Y' you will NOT be visible to public, maps, etc. Suggest leave it 'N'. Scroll down Your station info is below that 'profile' info, You should enter your antenna configurations while there. You also enter the city, country, etc for that specific station,...again, "Anonyn" 'Y' means that station WON'T be visible. Suggest leave it 'N'. then scroll down past the 'last signal' images, and click "save"
2025-12-27, 10:05
Now that your GPS problem is solved, there is another little detail to update
antenna description in the settings, this will help the servers to decode your signal this is mine and yours the settings part You can also update the firmware to 11B3 (even if it is labeled beta it is stable and it has some improvements for signal and some extra stuff to play with) https://docs.lightningmaps.org/station-o.../firmware/
2025-12-28, 19:57
(2025-12-27, 10:05)Eric.Wouters Wrote: Now that your GPS problem is solved, there is another little detail to update Hello, Is it possible to load this firmware version for the Blue Mini?
2025-12-28, 20:24
(2025-12-28, 19:57)ea3gkp Wrote:(2025-12-27, 10:05)Eric.Wouters Wrote: Now that your GPS problem is solved, there is another little detail to update yes... just make sure you get the 'blue.bin' file. See the PM I sent yesterday...
2025-12-28, 21:02
(2025-12-28, 20:24)cutty Wrote:(2025-12-28, 19:57)ea3gkp Wrote:(2025-12-27, 10:05)Eric.Wouters Wrote: Now that your GPS problem is solved, there is another little detail to update ok, thank you |
« Next Oldest | Next Newest »
| How does one become a receiver station builder? | Moonbouncer | 1 | 24,148 |
2020-04-30, 14:22 Last Post: vinesweather |
| Buying a receiver | Yoggie | 2 | 40,295 |
2017-05-24, 21:49 Last Post: allsorts |
| Looking for a receiver | va3mw | 4 | 43,461 |
2014-07-16, 15:46 Last Post: va3mw |
