Bad data on www.blitzortung.org page
For more than two days http://www.blitzortung.org/Webpages/inde...=en&page=5 page displays the wrong data on the number of discharges detected by the stations. Values ​​do not change, also did not change the number of signals. Date of last signal is still: 2014-10-24 8:40
(2014-10-26, 10:00)kriu Wrote: For more than two days http://www.blitzortung.org/Webpages/inde...=en&page=5 page displays the wrong data on the number of discharges detected by the stations. Values ​​do not change, also did not change the number of signals. Date of last signal is still: 2014-10-24 8:40
And, since the developers are obviously working on the server, your question is WHAT?
(2014-10-26, 10:11)Cutty Wrote: And, since the developers are obviously working on the server, your question is WHAT?
Just stopped in looking to see if there was an explanation for the same issues, not sure what we're missing that's so "obvious"?
Thanks for your most helpful reply Cutty.
Stations: 3017
Sad
Sad Apologies... my response hasty and very badly done, it even offends me as I look at it. I must have been having a really bad day.
It sure looks like something is broken, or turned off.. Let's see if we can get some answers..
Hi Folks,
I'm sorry,one of the databases has not been updated, I found the error, however, it had no effect on the calculations.
Egon
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 14,491 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 19,320 2024-08-20, 05:11
Last Post: gerbold
  Station 3012 in https://www.lightningmaps.org/ bakerkj 6 31,255 2024-04-16, 08:42
Last Post: jeanse
  Problems www.lightningmaps.org pnavoy 0 14,841 2023-09-16, 08:41
Last Post: pnavoy
  map.blitzortung.org down??? orion_jb2001 8 47,932 2021-08-09, 15:56
Last Post: NHSA_Rainer
