Often the connection to the Internet (router) is lost how to fix it?
Станции: 1684
Is the Blitzortung detector the only device having the issue?
Can you ping or access web page of the Blitzortung detector without any issues?
Вы используете kабель F/FTP или kабель или S/FTP kабель SF/FTP с H предусилитель?
https://ru.wikipedia.org/wiki/Витая_пара
(2017-03-22, 04:00)kevinmcc Wrote: Is the Blitzortung detector the only device having the issue?
I think malyan's controller isn't very happy. Over in the order status thread it's mentioned that the red H-field LED goes off. I think that refers to the LED on the H-field preamp board. That LED is connected across the 5 V supply of the pre-amp board. That 5 V pre-amp supply is fed directly from the regulated 5 V rail on the controller board.
The H-field pre-amp LED going off indicates a problem with the 5 V on that board. This could be a connection problem, poorly crimped plugs to screened cable, dry joint on the socket connections to either board. Or it's a problem with the 5 V rail of the controller, which I'd expect to be related to the power supply being used.
We need more information from malyan:
With everything connected up which lights are on, off, regulary flashing or randomly flashing 5 minutes after the unit has been powered up?
Can malyan get to the controllers web interface?
If so what does the Status > Controller / CPU section say?
I don't read or speak Russian so haven't any idea if this google translate is any good.
Я думаю, контроллер Малиана не очень доволен. В потоке статуса заказа указано, что красный светодиод H-поля гаснет. Я думаю, что это относится к светодиоду на плате предварительного усилителя H-поля. Этот светодиод подключен к источнику питания 5 В на плате предварительного усилителя. Это предварительное напряжение питания 5 В подается напрямую от регулируемой шины 5 В на плате контроллера.
Срабатывание светодиода предварительного усилителя H-поля указывает на проблему с 5 V на этой плате. Это может быть проблема подключения, плохо обжатые клеммы для экранированного кабеля, сухой разъем на разъемах на любой плате. Или это проблема с 5-вольтовой шиной контроллера, которую я ожидал бы связать с используемым источником питания.
Нам нужна дополнительная информация от malyan:
Что все подключено, какие лампы включены, выключены, регулярно мигают или случайно мигают через 5 минут после включения питания?
Может ли malyan попасть на веб-интерфейс контроллеров?
Если да, то о чем говорит раздел Status> Controller / CPU?
Я не читаю и не говорю по-русски, поэтому не имею ни малейшего представления, является ли этот перевод Google хорошим.
I took two semesters of Russian in college 17 years ago, I very rusty.
You probably are right about power issue.
I told him to make sure he had proper shielded cable for H-field.
FirmwareRev. 8.2 BLUE / Sep 29 2016 14:10:51
HardwareRev. 19.3 (PCB-Id 50)
Device-ID2600-2A00-0B51-3533-
HCLK / SYSCLK / PCLKs168 / 168 / 42 / 84 MHz
CPU28%, 34.7°C, 3.25V
Max. Memory usage114kB + 65kB for Signals
Signal Buffers15
Input Voltage4.73V
Станции: 1684
Availability100.00%
TypeMediatek with 115200baud (FW: AXN_3.20_3333_13022801,8030)
StatusActive, 3D-fix
Satellites8 tracked, 13 in view
Date/Time2017-03-23 10:41:47
Position56.844181° 35.838924° 120.4m
Smoothed56.844215° 35.839164° 130.4m (smoothed over 20m, 55s)
PDOP/HDOP/VDOP1.38 / 1.09 / 0.85
Sat. Signals (SNR)
28 20dB
30 23dB
13 18dB
8 17dB
15 40dB
20 34dB
7 24dB
5 23dB
11
27 17dB
18
17
21
PPS AccuracyMean: 11.8ns, Current: 0ns
Станции: 1684
Network cable Electraline FTP cat 5e 4х2х0.52 mm
Станции: 1684
Red H-Field LED is OK
Станции: 1684
The station registers signals at a distance of 2,500 kilometers, but communication with the Internet often disappears.
Станции: 1684
When connection is lost to internet, can you still access the detector web and ping 8.8.8.8?
Upgrade software to 8.3b2, this version is the most stable.
https://forum.blitzortung.org/showthread.php?tid=1623
Voltage maybe too low, I think that voltage should be 4.75v - 5.25v or 5v +/- 5%.
For H-Field F/FTP, S/FTP, or SF/FTP are best as the individual pairs are foil shield.
For network connection most cat 5 or better cable is fine.
When connection is lost to internet, can you still access the detector web and ping 8.8.8.8? - no
Upgrade software to 8.3b2, this version is the most stable. - Link to the new version is not available
Станции: 1684
(2017-03-24, 02:16)kevinmcc Wrote: When connection is lost to internet, can you still access the detector web and ping 8.8.8.8?
malyan has just answered that "no". That indicates to me that it is the LAN that has stopped working as the computer being used can't see the detector or the internet. As it does work sometimes I don't think that can be a routing configuration problem. Which really only leaves a problem with the LAN switch or router.
(2017-03-24, 02:16)kevinmcc Wrote: Upgrade software to 8.3b2, this version is the most stable.
malyan says the link is not available. I'm afraid that "it works for me" both the link above which takes you to the forum topic and the link in the first post to the firmware. I've been running 8.3b2 from not long after it was released, no problems and I have turned off the deafult daily reboot. My controller uptime currently 11 days, it's been up to 40 ish days before a power cut  forced a reboot.
(2017-03-24, 02:16)kevinmcc Wrote: Voltage maybe too low, I think that voltage should be 4.75v - 5.25v or 5v +/- 5%.
Looks on the low side to me as well. 4.75 to 5.25 V is the official USB specification but the cotroller isn't a true USB device. The measured voltage is not the complete story with power. Some 5 V power supplies have a lot of noise on thier output and this can cause the controller to do strange things. If malyan has access to an osciloscope that would show up the noise. Without a 'scope try several power supplies to see if there are any differences to the performance of the controller. One might be found that is nearer 5 V as well.
malyan you need to register the detector using the detector's web interface.
After registration you can access the webpage for the newer firmware.
  Internet connection problem Egon 2 8,837 2016-05-04, 16:10
Last Post: kriu
