blue system schematic
Where can I found the schematic and partlist of the blue system ?
(2017-07-26, 11:30)mirancek Wrote: Where can I found the schematic and partlist of the blue system
Kits come assembled with a few loose connectors etc that must be installed by the user.. connectors, etc.
Schematics and other parts lists are available to registered operators in the compendium section, and are not available publicly.
Parts you need to complete the boards are listed in the documentation.
https://docs.google.com/document/d/1KzPZ...h_DRVs/pub
You can buy all the parts when you order your board or you can try and source the parts locally if you like.
I found the prices a bit cheaper to order some of the parts with the board.
You will have to soldier them in place, but they are easy to soldier.
Also most but not all parts are needed, some are optional, read the documentation carefully.
  Schematic help Lawrence Stoskopf 7 74,847 2015-05-25, 03:24
Last Post: Lawrence Stoskopf
