GPS died?
The detector suddenly reported no GPS fix yesterday. "No valid 1PPS pulse" tried to warm restart the GPS, then Cold, then rebooot the card. Nothing. And when I got home I did the same. Still no GPS fix. And when I start the card, the green light on the GPS does not blink or light or nothing. (It blinked before until it got GPS fix, now, nothing)
What could it be? Did the GPS chip die? What should I try next?
-Snicker-
Stations: 1122
Are you 100% sure it is soldered correctly - if not .... resoldering
Removing: warm throughout one side a time and gently lift few mm
Even for trained, it can be a challange to solder it correctly
Welcome to the Club Snicker. I have an old system and my gps died a few weeks ago. But on the other side, it is not really dead. The PPS keeps going, but there is no fix. I can´t imagine whats wrong.
greez
dottore
Stations: 2116
(2014-08-01, 07:28)RichoAnd Wrote: Are you 100% sure it is soldered correctly - if not .... resoldering
I can try of course, but is seems very strange. Since it suddenly happened 2 days after init. Running fine all the time. And nothing moved or touched it when it when it suddenly stopped working.
-Snicker-
Stations: 1122
Please provide a log of the GPS. How was the reception before the module has died?
(2014-08-01, 11:17)Tobi Wrote: Please provide a log of the GPS. How was the reception before the module has died?
I don't know where I can find any logs? The reception was excellent. I had 14 satellites in view on ext. antenna mounted on the rooftop. And very fast fix position. And no GPS errors.
Now it gives me the GPS error a minute after boot. "No valid 1PPS pulse" no matter if the ext. antenna is connected or not. No green light next to the GPS chip.
-Snicker-
Stations: 1122
Is it possible to order a new GPS module to see if that fixes it?
-Snicker-
Stations: 1122
Hello! My gps module (system blue) not view satelits with external ant. log my gps:
PMTK863,0,0,56,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,91,92,93,94,95,96,97,98,99,100,101,102,103,104,105,106,107,108,109,110,111,112,113,114
2013-01-01 00:45:14 2101 | GPS: 43752418 | GPGGA,001456.799,,,,,0,0,,,M,,M,,
2013-01-01 00:45:14 2101 | GPS: 44006738 | GPGSA,A,1,,,,,,,,,,,,,,,
2013-01-01 00:45:14 2101 | GPS: 44412104 | GPRMC,001456.799,V,,,,,0.00,0.00,060180,,,N
2013-01-01 00:45:14 2101 | GPS: ERROR, year not between 2013 and 2031 (80)
2013-01-01 00:45:14 2101 | GPS: 80-01-06 00:14:56 lat:0.000000 lon:0.000000 alt:0.0 sat:0 inview:0 fix:1 integr:N pdop:0.0 status:V
2013-01-01 00:45:14 2101 | GPS: ===========================================
2013-01-01 00:45:15 2102 | GPS: Data ERROR
2013-01-01 00:45:15 2102 | GPS: 1PPS deviation too high 4394208. Reset counter!
2013-01-01 00:45:15 2102 | GPS: 1PPS ERROR
2013-01-01 00:45:15 2102 | REMOTE-CONFIG: IP to hostname www.lightningmaps.org NOT found ...
2013-01-01 00:45:15 2102 | GPS: 38310840 | GPGGA,001457.799,,,,,0,0,,,M,,M,,
2013-01-01 00:45:15 2102 | GPS: 38565148 | GPGSA,A,1,,,,,,,,,,,,,,,
2013-01-01 00:45:15 2102 | GPS: 38969064 | GPRMC,001457.799,V,,,,,0.00,0.00,060180,,,N
2013-01-01 00:45:15 2102 | GPS: ERROR, year not between 2013 and 2031 (80)
2013-01-01 00:45:15 2102 | GPS: 80-01-06 00:14:57 lat:0.000000 lon:0.000000 alt:0.0 sat:0 inview:0 fix:1 integr:N pdop:0.0 status:V
2013-01-01 00:45:15 2102 | GPS: ===========================================
2013-01-01 00:45:16 2103 | GPS: Data ERROR
2013-01-01 00:45:16 2103 | GPS: 1PPS deviation too high 4523900. Reset counter!
2013-01-01 00:45:16 2103 | GPS: 1PPS ERROR
2013-01-01 00:45:16 2103 | REMOTE-CONFIG: Server switched to 0
2013-01-01 00:45:16 2103 | REMOTE-CONFIG: ERROR, NO NETWORK AVAILABLE!
2013-01-01 00:45:16 2103 | GPS: 32425800 | PMTK867,0
2013-01-01 00:45:16 2103 | GPS: 34318296 |
What i must do?
Did you solve the issue? If not, we need your station id.
I have had same issue since feb 2018, not solved yet. Station 804
Hi All, I have a similar problem.
This appears to be something to do with the GPS Antenna. The red GPS blinks without the antenna and with one antenna I get sat data, but no pps and with another diferent antenna, pps data, but no sat data.
Apart from this the board appears to function correctly and it updated firmware with no problem.
I would like to get active again, but without further information about why this is happening I can not just keep buying different GPS Antennas until I get one that works.
Thank you in advance.
Kindest regards,
Brian.1856 Vilaboa.
Brian, have you tried doing a factory reset?
I'm fairly certain that you know about the proper placement of GPS antennas. That being said, where is your antenna? Could you move it?
(2019-06-07, 14:46)readbueno Wrote: Hi All, I have a similar problem.
Kindest regards,
Brian.1856 Vilaboa.
Thanks Mike, Yes. I have tried resetting. The antennas were in the same place as the previous antenna and that worked ok.
I thought it was the actual GPS module, but that seems to work normally as long as no external antenna is plugged in.
It may be to do with the pre-amp in the antenna? Although it has 3.2 volts at the centre pin.
Brian.
The center pin of the RG-6 coax should have at least 4 or 5 volts on it. Maybe you need to shorten it.
What is your voltage on the status page? That should be close to 5 VDC.
(2019-06-07, 16:07)mwaters Wrote: The center pin of the RG-6 coax should have at least 4 or 5 volts on it. Maybe you need to shorten it.
Hi Again, The Coax on the GPS antenna is an unknown mini-coax and the output from the GPS module is only 3.2 volts.
The power supply is adjustable and it is set just where the CPU voltage measures 3.25 volts this is, on this board, about 5.1 volts.
The voltage at the e field pre-amp is the same more or less as the input voltage.
The GPS Pre-amp says 3 to 5 volts working, but it is limited by the GPS module itself.
What is more of interest is why something is causing the buffer over run, that does not permit both functions to happen at the same time?
I have ordered the original cheapy eBay GPS antenna again, 3 weeks wait? As it did work until the landscaper weedwacked the cable! Angry
For the other two antennas that I got to replace that one, I went a little more up-market and neither of them appear to work?
This would normally point to the problem being somewhere else, but as far as I can tell the board is not showing any errors, except when a GPS antenna is plugged in.
Brian. 1856 Vilaboa
P.S. I see I have lost the station details at the server too. I have not tried to re-assign until I get something that works.
How does your pps signal looks like ? Mine is like this and not good.
(2019-06-07, 15:19)readbueno Wrote: ... It may be to do with the pre-amp in the antenna? Although it has 3.2 volts at the centre pin.
Brian.
I see now. I understood this to mean the E-field preamp.
Brian.
Yes, As far as I can tell nearly all these GPS antennas have a pre-amp, probably to overcome the losses in the crappy mini-coax?
