earth ellipsoid - smallest number of stations
thank you for your answer. Indeed it helped a lot.
Reading your reply I wondered about two aspects:
1) Did I understand correctly that the number of "locators" is as high as the required "minimum number" or can more stations be used if the        required minimum is smaller than the maximum of 12?
2) Is the required minimum calculated for every stroke or for a whole region?
best regards,
PothThom
Stations: 416
RE: earth ellipsoid - smallest number of stations - by RiePa - 2016-03-31, 09:22
  The number of hits to the database and the appearance of the map - myblitzortung brzanek 2 10,843 2021-01-26, 14:18
  Archive data / Export to Google Earth Hoffmann 7 42,334 2015-07-07, 10:31
