Help new system blue
#26
Patience! Don't throw it through the window. It will work it just may take a little more time. The first thing is to get it to light up.
The USB connector on the board is a USB mini-B, most phones do not use this. So yes you will need the proper connector or an adaptor cable.
After you have got past that stage you can then use your computer to get access to the controller via your router.
At First switch on I could not find the ip address that the router had assigned either. I used "Angry IP scanner" and that found it. There are other programs that will work for this as well.
I was then able to access the controller.
The only dumb questions are the ones that you did not ask until it was too late. If you have a problem ask in the forum.
Good Luck!
Brian.
Help new system blue - by mikey141 - 2017-09-17, 13:37
RE: Help new system blue - by pasense - 2017-09-17, 14:04
RE: Help new system blue - by mikey141 - 2017-09-17, 14:12
RE: Help new system blue - by pasense - 2017-09-17, 14:20
RE: Help new system blue - by mwaters - 2017-09-17, 14:22
RE: Help new system blue - by mwaters - 2017-09-17, 14:33
RE: Help new system blue - by mikey141 - 2017-09-17, 14:52
RE: Help new system blue - by mwaters - 2017-09-17, 14:56
RE: Help new system blue - by mikey141 - 2017-09-17, 14:59
RE: Help new system blue - by mikey141 - 2017-09-17, 15:22
RE: Help new system blue - by pasense - 2017-09-17, 15:44
RE: Help new system blue - by mikey141 - 2017-09-17, 16:41
RE: Help new system blue - by pasense - 2017-09-17, 16:47
RE: Help new system blue - by mikey141 - 2017-09-17, 18:23
RE: Help new system blue - by pasense - 2017-09-17, 18:31
RE: Help new system blue - by mwaters - 2017-09-17, 18:31
RE: Help new system blue - by mikey141 - 2017-09-17, 18:43
RE: Help new system blue - by pasense - 2017-09-17, 19:02
RE: Help new system blue - by mikey141 - 2017-09-17, 19:08
RE: Help new system blue - by pasense - 2017-09-17, 19:10
RE: Help new system blue - by mwaters - 2017-09-17, 21:21
RE: Help new system blue - by allsorts - 2017-09-17, 19:53
RE: Help new system blue - by mikey141 - 2017-09-17, 20:00
RE: Help new system blue - by mwaters - 2017-09-17, 21:23
RE: Help new system blue - by mikey141 - 2017-09-17, 20:05
RE: Help new system blue - by readbueno - 2017-09-18, 00:18
RE: Help new system blue - by mwaters - 2017-09-18, 01:27
RE: Help new system blue - by kevinmcc - 2017-09-18, 01:27
RE: Help new system blue - by allsorts - 2017-09-22, 22:51
RE: Help new system blue - by cutty - 2017-09-18, 14:13
RE: Help new system blue - by mikey141 - 2017-09-18, 16:33
RE: Help new system blue - by mwaters - 2017-09-18, 16:39
RE: Help new system blue - by mikey141 - 2017-10-01, 17:25
RE: Help new system blue - by mwaters - 2017-10-01, 17:55
RE: Help new system blue - by readbueno - 2017-10-01, 18:29
RE: Help new system blue - by mwaters - 2017-10-01, 18:33
RE: Help new system blue - by readbueno - 2017-10-01, 18:45
RE: Help new system blue - by mikey141 - 2017-10-01, 19:06
RE: Help new system blue - by readbueno - 2017-10-01, 19:43
RE: Help new system blue - by mikey141 - 2017-10-01, 19:51
RE: Help new system blue - by readbueno - 2017-10-01, 20:13
RE: Help new system blue - by cernese - 2018-02-06, 23:24
RE: Help new system blue - by readbueno - 2018-02-07, 00:41
Users browsing this thread: 15 Guest(s)
