Efficiency
#90
The only comment I have regarding your station: it seems you have connected the two H field antennas to channel B and C;  it would be better to shift to A and B. You can see that from the color of the traces in the signal plots below. I copied these from the list of strokes where your station was involved and they show typical signals.
Hi pasense,
