Get no IP - What's wrong?
Hello community,
  I'm new here and got my kit today and soldered right away.
  It lacks only the 2 filter IC's because I am not clear in which filter I should solder them.
  There are 4 on the circuit board.
  Does not it matter?
  First everything built into the case and then connected a 5V 2A power supply.
  The red power LED lights up and it beeps twice -
  then the mode LED flickers very weak and after some time it beeps again.
  The LEDs on the network socket light or flicker with the traffic on the network.
  Unfortunately, I get from DHCP (SBS Server 2011) obviously no IP address.
  Even a test for a new router with DHCP was unsuccessful.
  Have again taken the board out of the housing and tested all solder joints - looks good.
  Inside, the red LED on the GPS receiver is flashing. There is a new GPS antenna connected.
  The 2 crystals are on the correct position.
  Does anyone have a tip for me ....
  Greetings from Carinthia,
Get no IP - What's wrong? - by glump - 2017-11-28, 13:27
RE: Get no IP - What's wrong? - by readbueno - 2017-11-28, 13:48
RE: Get no IP - What's wrong? - by glump - 2017-11-28, 14:05
RE: Get no IP - What's wrong? - by glump - 2017-11-28, 14:31
RE: Get no IP - What's wrong? - by allsorts - 2017-11-28, 16:59
RE: Get no IP - What's wrong? - by DelandeC - 2017-11-28, 18:52
RE: Get no IP - What's wrong? - by glump - 2017-12-01, 14:31
  Using Wire Shark to recover your IP address Mike6158 3 34,480 2017-04-19, 17:49
Last Post: james_stier
