#32
Go to the status page of your controller, make a note of the "Device ID:" under "Controller / CPU". Log into
http://en.blitzortung.org/live_lightning_maps.php
go to the site login page top right and enter your existing user name into the "New Username" field and the code found above into the box marked "Register Code". This will create a site user, register your controller and connect your forum username with site username.
Once logged into the site you can update the information about your set up, aerial type(s), which channel has what aerial etc. On the site Input 0 is Ch1A, Input 1 Ch1B etc and dimensions are in mm.
RE: New member, having some problems with H-field big interference bursts.. - by dupreezd - 2018-10-03, 15:44
  Fault mode after big electrostatic discharges. ant01n3 1 14,041 2024-01-30, 22:55
Last Post: dupreezd
  H field big difference in gain DrRobin 16 126,602 2016-10-19, 22:32
Last Post: allsorts
