Ethernet speed connection 10/100 on PCB 19.5
(2020-03-01, 15:59)mwaters Wrote: Thank you, Dries! I see that you're pretty knowledgeable about this. I just learned something.
I have a homemade pfSense router, which feeds a D-link 16-port switch, and a wireless router and all other devices are connected to that. Sounds like if I test the speed, I'll find that the 10mbps port on the lightning receiver isn't slowing the rest of my LAN down.
I don't know what a managed switch is.
Managed switch you can log in to the switch can change parameters.
Configure the ports to be for VLANs, Trunks vs Access, manually set speed and duplex, etc...
Normally used in the business world.
RE: Ethernet speed connection 10/100 on PCB 19.5 - by kevinmcc - 2020-03-07, 14:23
  Firmware 10 on System Red PCB 10.5 - firmware bug ??? mmlightning 1 12,356 2025-02-27, 08:37
  internet speed jrm30655 11 80,591 2021-03-10, 03:57
Last Post: aprwx
  100 watt ham transmitter near a blue davidsaroff 9 55,111 2020-10-19, 16:35
Last Post: braind
  System Blue PCB 19.4 vs 20.6 dhitzigrath 6 49,578 2019-11-22, 04:48
Last Post: kevinmcc
  PCB 19.5 toutoumeteo 4 30,854 2019-06-02, 19:36
Last Post: Egon
