(2021-03-16, 21:27)Art_Brown Wrote: User Name: Art_Brown
Station 2285
USA/Caifornia
Sataion not listed on list or shown on map at https://map.blitzortung.org/#12.41/37.73743/-121.93404
Hello Art:
Your station DOES NOT SHOW because you are misconfigured.
https://www.blitzortung.org/en/login.php
You have selected 'anonymous' on your station configuration page, which prevents ANY of your station data being displayed.
You are sending signals, and they are being recorded, etc, but your data is NOT visible because of your selection.
[Image: 2285%20anon.png]
While you are changing the
Anonym: Y to  Anonym N,  please configure your antennas etc correctly.
  https://forum.blitzortung.org/showthread.php?tid=2863
Your system signals are processed as 'server's best guess' without the correct antenna configurations.
Also note you have your optional filters set so NO frequency higher than 25kHz will be processed.  Unless you have extreme noise at normal settings above 25kHz, you are NOT sending best data with the low end bandwidth only. Strongly suggest turn them off, and re-optimized your station.
As to other questions regarding data in that above thread, (tid 2863) please note  the ONLY official data is what is on the OFFICIAL site, blitzortung.org.  NO Adjunct site will present correct, up-to-the moment data, and statistics aren't computed 'officially' and will be at variance with 'officially' derived data.
Station not on List - by dbromwich - 2019-01-23, 12:12
RE: Station not on List - by Egon - 2019-01-23, 15:20
Not on List. ETC - by geofabryka - 2019-07-21, 06:26
RE: Station Isn't Recognized. Not on List. ETC - by cutty - 2021-03-16, 23:59
  Station List not showing any United Kingdom stations dgoadby 2 34,758 2019-04-15, 16:35
Last Post: dgoadby
  Removing Station 723 from list Ian.Cooke 5 58,576 2015-02-03, 20:39
Last Post: Toxic
