9.4 Blue 19.3 Board Can't update firmware
(2025-03-10, 18:24)ni5f Wrote:
(2025-03-10, 17:19)mendip_defender Wrote: Login via the webpage of the Station,
Tools > Firmware > Upload Firmware ( Download the file from https://docs.lightningmaps.org/station-o.../firmware/ )
Once that has uploaded then click "Start Update"
It should reboot.
Thanks for the response. However, when I log into my device on my local network, nnn.nnn.nnn.112, I do not see anything labeled Tools. I have 'Login Status About' at the top and vertical sections labeled 'Tracker Amplifiers ... Other Parameters'. How do I find 'Tools | Firmware' ?
Then you will need to click on Login, then put in your username and password that you set when you setup the device. Then the other menus will be there.
Station 2828 - LM or BT
Stations: 2828
RE: 9.4 Blue 19.3 Board Can't update firmware - by mendip_defender - 2025-03-10, 20:18
  Firmware 10 on System Red PCB 10.5 - firmware bug ??? mmlightning 1 11,990 2025-02-27, 08:37
  Blue Board 403 or L403 detached SkippyOz 3 23,753 2021-06-11, 08:44
Last Post: koleto
Smile System Blue 19.5 Board Assembled For Sale carolinastormwatch57 1 17,648 2021-02-12, 10:30
Last Post: Alvarezz
  System Blue PCB 19.4 vs 20.6 dhitzigrath 6 48,576 2019-11-22, 04:48
Last Post: kevinmcc
  Blue Board L104 C605 Detached bretberger 7 45,246 2019-09-02, 21:03
Last Post: mwaters
