Big hole around Gulf of Thailand
[quote pid="27446" dateline="1758212092"]
You have a very valid point, but we can't have everything  Blush
I have tested and practiced in Switzerland, now packed the antennas and detectors with good quality power supply and shielded cables and I had some success with remotely guiding in order to find a good antenna placement (e.g. not on top of the air conditioning units). Not ideal for sure, and it require collaboration and patience from the host for a few days. When they run, #3111, #3113, #3155 & #3157 provide some useful signals. How do I know ? I ran query for all strikes in Africa below 20N (50 million km2) and the listed stations are involved in 99% of the strikes.
[/quote]
I looked at the station reports for those four stations.  The green line is very low in the graphs, but the other lines look very encouraging.  I think you have accomplished quite a lot.  Thank you.
I see that for each of these four stations, you chose ferrite-rod antennas.  I think that is smart.  For the host with what might be limited experience, any other kind of H antenna has more ways it might go wrong.
Do you add shielding to the FRAs?
Do you mount the FRAs and preamp to a board, so reduce the risk the host will damage the fine wires from the FRAs?
AA2KW - Station 3205
RE: Big hole around Gulf of Thailand - by oppedahl - 2025-09-18, 16:35
  big lightning storm seen from space davidsaroff 6 49,870 2020-06-02, 20:19
Last Post: mwaters
  The hole world at the same time dusanofrode 4 39,380 2018-07-29, 15:58
Last Post: DnNclsn
  Phoenix, Arizona, a hole in the coverage? jerrya 5 52,107 2014-07-29, 12:13
Last Post: Kevin.Beverage
