The signal data is still not updating on the online panel
(2025-09-27, 18:20)GeezerD Wrote: After taking a quick look at station 2463, at
https://map.blitzortung.org/statistic_0....ation=2891
.. I would suggest that there is some kind of network connectivity problem. It looks like you've fixed your GPS problem from earlier this week.
If I were in your place, I would go to Settings tab on your local Blitzortung controller page, turn on Debug Network under the Debug heading, and then look at the debug logs under the Tools tab, to see if I could discover any problems there.
I tried turning the station off for some time, which caused the signal to be missing for several days.
Also, I would like to note that on the Blitzortung online map I can see the yellow tracers from my station to the lightning strikes, as well as the timely update of the 'Last Signal:' status. This shows that the signals do reach the server, but for some reason they are not updating on the online panel
PS: There are no errors in the debug logs related to the internet connection, so that should be fine
RE: The signal data is still not updating on the online panel - by Svarshdrgdgchik911 - 2025-09-27, 18:34
  System Blue Basic - Indicator Panel for Enclosure? DrFX 17 39,774 2025-09-19, 01:35
Last Post: davidmc36
