Pulling RF off the H-amp?
I would use a balanced amp. Opamps are cheap. With a balanced amp you are less likely to get in trouble with noise on ground since ground is not a reference potential. Ground noise can affect the signal you tap off, but worse is that it can sneak back into the BO system.
I'm a trouble shooter, and you would not believe how many problems we pin down to people believing that ground is the same in a system of connected devices.
Pulling RF off the H-amp? - by b.e.wilson - 2014-08-20, 01:10
RE: Pulling RF off the H-amp? - by b.e.wilson - 2014-08-20, 01:41
RE: Pulling RF off the H-amp? - by RichoAnd - 2014-08-20, 05:42
RE: Pulling RF off the H-amp? - by Bonzo - 2014-08-21, 17:44
RE: Pulling RF off the H-amp? - by b.e.wilson - 2014-08-21, 17:58
RE: Pulling RF off the H-amp? - by Bonzo - 2014-08-21, 19:04
RE: Pulling RF off the H-amp? - by Einar - 2014-08-21, 20:09
RE: Pulling RF off the H-amp? - by b.e.wilson - 2014-08-22, 01:40
RE: Pulling RF off the H-amp? - by RichoAnd - 2014-08-22, 09:37
  System BLUE / capability to handle external RF fields tkuhmone 10 82,289 2015-07-06, 10:47
Last Post: tkuhmone
