network cable connection issue
No need for a shielded network cable to your LAN mate. You can ground the controller via the ground screw to a good earth stake (or water pipe IF it is metallic all the way, a lot of modern Aussie pipes are poly).
Check for DHCP issues with your router maybe?
Edit: you beat me to it. Dry joints don't help :-(
Stations: 915, 966
network cable connection issue - by Mozi - 2015-01-23, 13:11
RE: network cable connection issue - by seemakm - 2015-02-17, 12:24
  Firmware issue (8.0 RED) Geewizard 5 41,600 2016-08-27, 14:12
Last Post: Geewizard
