login
Hi Blitzfeuer,
the login as participant requires another password, different from the Forums password. The access it, go to the blitzortung.org web page, enter under the heading "participant area" the "station list", enter your station number (1863) - not forgetting to remove the leading asterics - and then you get to a page where your station is listen. Click an the yellow symbol at the left, then you have the page with all infos concerning your station. In the left column, there is a point "login", try that and then you can say "forgot password".
To change the data concerning your station, the only way I found is  a bit different: use the "Login" field at the start web page (top right) with your brand-new password, then you get a page where you can put in all data. Good luck!
Stations: 1836
login - by andyweather - 2015-04-18, 15:56
RE: login - by Tobi - 2015-04-18, 17:46
RE: login - by andyweather - 2015-04-18, 21:33
RE: login - by cutty - 2015-04-19, 00:35
RE: login - by Blitzfeuer - 2017-07-26, 16:51
RE: login - by Blitzfeuer - 2017-07-12, 18:48
login - by DelandeC - 2017-07-12, 19:01
RE: login - by pasense - 2017-07-27, 10:10
RE: login - by Blitzfeuer - 2017-07-27, 16:02
RE: login - by Blitzfeuer - 2017-07-28, 20:13
RE: login - by Blitzfeuer - 2017-08-01, 17:03
RE: login - by pasense - 2017-08-01, 18:48
Smile How can I get my login as contributor? psper 1 16,609 2017-06-22, 18:05
Last Post: psper
  Cannot login any more Sebastian.Mahr 6 44,604 2015-06-10, 07:52
