DHCP Failure
(2015-06-01, 13:55)Steph Wrote: I can't help, sorry. If you see that it's transmitting something, I would start debugging with tcpdump.
But maybe someone else has a better idea.
Thanks Steph, I will try this over the next weekend. Today was a free day and I tried to streamline my network (full of all kind of wireless devices with all kind of default settings).
I made everything fit into 192.168.1.xxx including the router so I can keep the subnet mask of the router to 255.255.255.0.
Also new firmware for the router, shut everything out and tried only to connect the station as the only device. Nothing actually worked  and the station is unfortunately still unreachable (no ping reached it even with numerous resets)
As this was an issue which degraded over time I presume there must be an malfunction either in the router or in the board itself (the router seems to provide dhcp services to other devices and is quite fast with handling my connection). Will also try to take the station to a friend so I can test it on his router.
Stations: 960
DHCP Failure - by Mihai-Florin.Necula - 2015-06-01, 09:32
RE: DHCP Failure - by Steph - 2015-06-01, 12:25
RE: DHCP Failure - by Mihai-Florin.Necula - 2015-06-01, 12:44
RE: DHCP Failure - by Steph - 2015-06-01, 13:14
RE: DHCP Failure - by Mihai-Florin.Necula - 2015-06-01, 13:40
RE: DHCP Failure - by Steph - 2015-06-01, 13:55
RE: DHCP Failure - by Mihai-Florin.Necula - 2015-06-01, 18:43
RE: DHCP Failure - by Steph - 2015-06-01, 18:49
RE: DHCP Failure - by cutty - 2015-06-02, 12:25
RE: DHCP Failure - by Mihai-Florin.Necula - 2015-06-02, 15:26
RE: DHCP Failure - by cutty - 2015-06-02, 15:53
RE: DHCP Failure - by Mihai-Florin.Necula - 2015-06-02, 16:18
RE: DHCP Failure - by cutty - 2015-06-02, 20:56
RE: DHCP Failure - by Mihai-Florin.Necula - 2015-06-02, 21:03
RE: DHCP Failure - by Mihai-Florin.Necula - 2015-08-06, 08:32
