Question about the antena in system Blue
(2016-05-14, 23:19)BlackRockShooter Wrote: hi,
i have some questions about the antena of the blue system.
1) as i remeber right i need the h-field amplifier with the ferrite antena and i need the e-field amplier. the e-field works with a normal wire antena right???
2) were can i place those antena corectly? the h-field in my room and the e-field somwhere outside? because i only have a terace and so i dont know if the e-field antena workes there. can i place it at the attic or somewhere at the roof?? is this enought?
thank you for the help  Smile
PS: sorry for the bad english  Big Grin  Tongue
1) You don't need both antennas, you'll be fine with either an H-field or E-field antenna.
2) I might be wrong, but I believe the H-field antenna (ferrites, loop antennas etc.) CAN be placed inside and still produce good results. The E-field antenna is sensitive to noise in the electric field and should not be placed inside, the E-field can be quite noisy due to other electronics.
RE: Question about the antena in system Blue - by Jorgeminator - 2016-05-14, 23:42
  System Blue Network Interface Question chevyman142000 13 61,316 2016-09-19, 20:21
Last Post: chevyman142000
  System Blue - Rocker Switch Question chevyman142000 5 25,531 2016-09-09, 16:57
  One Antena in Azores is enough ? psper 9 49,552 2016-05-31, 17:38
  Registering new system question.. Aythya 8 43,414 2016-05-12, 07:21
Last Post: Knolau
  Question about System Blue parts. kevinmcc 2 16,962 2016-05-06, 23:52
Last Post: kevinmcc
