(2016-05-31, 21:30)RichoAnd Wrote: Many have questions about antennas
I made a mini guide to getting started making antennas
Corrections reserved
Good luck
Richo
http://en.blitzortung.org/Compendium/Doc...tennas.pdf
...If you wish I can help with ready-wound transformers
Dear RichoAnd,
many thanks for putting together the antenna guide. I received my system BLUE yesterday and assembled it. Now I want to build the antennas
I read your guide: http://en.blitzortung.org/Compendium/Doc...tennas.pdf
I reviewed this page: http://en.blitzortung.org/cover_your_area.php
I read the documentation: http://en.blitzortung.org/Compendium/Doc...B_14.1.pdf
and the assembly guide: http://de.blitzortung.org/Compendium/Doc...B_20_1.pdf
Question 1: 75 Ohm coax loop antenna (H-Field)
Am I correct to assume that a complete coax loop antenna consists of three loops (not to be confused with wire turns)?
And the connections are:
A-1 = 1st loop conductor
A-2 = 1st loop conudctor
GND = 1st loop shielding (braid)
B-1 = 2nd loop conductor
B-2 = 2nd loop conudctor
GND = 2nd  loop shielding (braid)
C-1 = 3rd loop conductor
C-2 = 3rd loop conudctor
GND = 3rd loop shielding (braid)
Now, while all documents suggest three turns for each loop, the original instructions describe a diameter of 180 cm and your most recent guide 100 cm. Would a 180 cm diameter give a better reception? I have the attic space available. Or is 100 cm better to avoid noise etc.? What about the North South / East West directions? First loop N/S (A-1 and A2, second (B-1 and B-2) E/W and the third? Or will the arrangement be similiar to your recommendations for the ferrite rods, i.e. each loop 90° perpedicular to each other and no relation to the cardinal directions?
Question 2: ferrite rod antenna array (H-Field)
Your instructions state to arrange them 90° perpendicular to each other, while this page http://en.blitzortung.org/cover_your_area.php shows something else. Which ferrite antenna rod arrangement yields the best results?
I'm sorry for these probably very basic questions. I just want to do everything correctly.
Thank you!
WX3080
Stations: 1471
RE: Antennas for System BLUE - Mini Guide - by WX3080 - 2016-06-12, 08:15
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 17,282 2025-04-19, 23:25
Last Post: DrFX
  Blue Mini Marcel_1 1 3,861 2025-04-01, 19:15
Last Post: Marcel_1
  Metal housing for System Blue Mini blt 10 7,956 2025-03-09, 08:27
Last Post: DrFX
  mini blue icpass 1 6,156 2024-09-02, 05:14
Last Post: gerbold
  Any benefit to running a red and mini blue systems together Broms 2 5,444 2024-08-22, 15:44
Last Post: Broms
