Blitzortung Detector
(2017-06-10, 08:47)DelandeC Wrote: Hello,
The assembly is quite straightforward because there is only through hole components.
I would advise to process by component height. The smallest first.
Pay attention on transformers. Align the withe dot with the mark on the PCB. This is the same for the LP filter if you have that option.
And sure the polarity of the LEDs if you have taken the housing option.
Feel free to ask if you need help Wink
Hi Clemande
Thanks for your reply. Good to hear that assembly is straightforward. I saw the online documentation and got a bit worried.
Your advice is very good. I'll copy it into a document.
I'll ask if more help is needed.
regards
Dieter
Blitzortung Detector - by faustdownunder - 2017-06-10, 03:19
Blitzortung Detector - by DelandeC - 2017-06-10, 08:47
RE: Blitzortung Detector - by faustdownunder - 2017-06-11, 06:36
RE: Blitzortung Detector - by kevinmcc - 2017-06-11, 02:57
RE: Blitzortung Detector - by faustdownunder - 2017-06-11, 06:40
RE: Blitzortung Detector - by allsorts - 2017-06-11, 20:03
RE: Blitzortung Detector - by tbaggett - 2017-06-11, 23:10
RE: Blitzortung Detector - by kevinmcc - 2017-06-12, 00:17
RE: Blitzortung Detector - by allsorts - 2017-06-12, 02:13
  Detector at high altitude glacier 6 32,858 2014-08-05, 08:57
Last Post: glacier
