#21
(2017-08-12, 06:37)Tobi Wrote: @djhuft: You did some great work! Smile A long time ago I did use a soundcard to check and identify different sources of noise like you did with the SDR. Worked great. It's normal to see submarine or time sync transmitters.
Thanks! It was very interesting to do this work and see what I found. Hopefully it can be useful or at least interesting to others.
RE: SOLVED: Identifying interference with oscilloscopes and software-defined radio - by djhuft - 2017-08-13, 01:43
  Possibility of contributing to a second-tier experimenta hardware / software effort? louloulou 0 8,729 2020-08-16, 19:04
Last Post: louloulou
  Identifying which controller I'm looking at Dale.Reid 3 25,675 2016-06-20, 14:19
  NeB Q: Will nearby FM Radio Cell towers cause problems br1ght 2 21,799 2015-09-18, 20:53
Last Post: br1ght
  Gain settings by software? PA4EME 4 38,055 2014-09-07, 21:14
