System Blue Voltage regulator and antenna
Hello: I just received my new system Blue (Thank you Egon!) and am starting the assembly. I have two questions:
1  My board is marked PCB 20.4. Am I correct that I do NOT have to follow step 2.3 in the documentation? This is in regards to the voltage regulator extension.
2  In the description of system Red, there is a discussion on shielding the ferrite antennas, while in the System Blue documents it appears as if this is not necessary. Is this right?
Thank you,  Steve
System Blue Voltage regulator and antenna - by SteveQlQ - 2017-08-11, 15:05
  Blue e-field antenna question llowrey 2 14,150 2021-07-06, 14:34
Last Post: llowrey
  blue ferrite / loop antenna connection? MTO-Mareuil 1 12,127 2020-10-20, 11:43
  GPS antenna SYSTEM BLUE ! IK1TTD 9 59,383 2020-06-03, 12:16
Last Post: GJ7DNI
  Blue System: PreAmp & Antenna Questions BassJohn 5 35,288 2018-02-28, 08:41
Last Post: BassJohn
  Blue H field Ferrite antenna in L or Delta shape? nellyt 8 60,109 2017-03-30, 03:06
Last Post: Mike6158
