Bug:
The map does not show when I have IPv6 enabled in my browser (Firefox 29.0.1). I only get a empty square where the map is supposed to be. If I disable IPv6 in Firefox (network.dns.disableIPv6=true) everything works. I have a working IPv6 connection and other websites using IPv6 works fine. I also tried in Internet Explorer and Chrome with the same result.
Suggestion:
You should look into replacing polling for new data with pushing new data from the server using the WebSocket API (http://apress.jensimmons.com/v5/pro-html...g/ch7.html). This should save you bandwidth usage and allow you to send each event without delay.
Stations: 702, 1109
  Request to correct the position of station on the map www.lightningmaps.org Station_Roko 1 3,802 2025-07-02, 16:46
Last Post: Asbjorn.Aamot
  station 3021 in https://www.lightningmaps.org jeanse 1 6,131 2024-08-20, 05:11
Last Post: gerbold
  LightningMaps.org - Blue Dot in Wrong Place GlenVision 4 7,805 2024-08-07, 17:02
Last Post: mendip_defender
  Problem with lightningmaps.org JungMich 3 8,787 2024-07-06, 17:17
Last Post: gerbold
  lightningmaps.org/realtime Blubbel 0 4,893 2024-07-01, 07:29
Last Post: Blubbel
