Nearby Power Lines
#20
I wanted to add another data point to this: my house is about 170 meters from a main quad-circuit EHV right-of-way (I assume 345 kV, based on the type of towers). I have no problems with either E- or H-field operation.
Edit: apparently, at least one circuit (probably the double-line one) is 230 kV per OpenStreetMap. I was close Smile I think I'll verify that myself at some point. I wonder if a "tongue test" would work?
Stations: 1013
RE: Nearby Power Lines - by W3DRM - 2014-08-20, 19:43
  E-Field Antenna and 60 Hz power lines waysta 4 23,687 2017-06-09, 23:11
Last Post: radiofarol
  NeB Q: Will nearby FM Radio Cell towers cause problems br1ght 2 15,431 2015-09-18, 20:53
Last Post: br1ght
