Nearby Power Lines
#21
(2014-07-14, 23:54)Cutty Wrote:
(2014-07-14, 23:36)MeteoCercal Wrote: For this type of problem (near high voltage power lines) what's the best system: H-Field or E-Field?
It took me two months to find the one sweet spot in my garage, out of the entire dwelling, that the H field would work with good effect, consistently.
When I finished building it, I just chucked my H field amp up on a book case in my study to test it - worked brilliantly (and is still one of the better performing UK stations) I have only moved it to put some copper foil shielding on it :-) My E Field antenna is outside, mounted on an external wall, and can I get even a fraction of the performance out of it? can I heck...
Stations: 700
RE: Nearby Power Lines - by W3DRM - 2014-08-20, 19:43
  E-Field Antenna and 60 Hz power lines waysta 4 23,551 2017-06-09, 23:11
Last Post: radiofarol
  NeB Q: Will nearby FM Radio Cell towers cause problems br1ght 2 15,344 2015-09-18, 20:53
Last Post: br1ght
