map rendering problem
Greetings from KX4TD!
I just setup Raspberry Pi 3+ using NOOBS SD. My browser is Chromium (as supplied by NOOBS and updated).
https://map.blitzortung.org/?y#10/34.8101/-83.8771 map is inverted (see attachment).
https://www.blitzortung.org/en/live_ligh...php?map=32 map is OK.
(2020-08-27, 15:08)KX4TD Wrote: Greetings from KX4TD!
I just setup Raspberry Pi 3+ using NOOBS SD. My browser is Chrome (as supplied by NOOBS and update).
The map is inverted.
Works fine on my other devices and OSs.
Greetings from W0BTU! Which map?
  Vector map - choosing map style Sparkee 2 21,690 2021-09-28, 09:28
Last Post: Sparkee
