Power via POE Splitter
Has anyone tried powering a System BLUE via a POE (802.3af or 802.3at) splitter?
Since I have a POE capable switching, this seems like a good option to simplify the wiring.
Thanks.
Jeff
You are probably looking for similar devices.
https://www.adafruit.com/category/144
I had considered the passive PoE injectors myself for when I was planning to move my station.
Just a word of caution on the PoE converters, they may or may not work well, just like some USB power supplies may are may not work well.
I tried a high end audio 5v power supply and the EMI was so bad I could not use it.
You'll have to experiment, see what works.
Please report back how they worked or did not work when you do experiment.
I bought a DSLRSKIT PoE to USB (A female) splitter. It's currently very close to the SYSTEM BLUE, I'm waiting on a shielded RJ-45 coupler so I can move it about 3' away with some sheilded Cat 6.
The noise from the P/S is displayed at https://flic.kr/p/2koCqFA and https://flic.kr/p/2koBNzS.
My noise floor seems a bit high (https://flic.kr/p/2koBVXs), but the H-field antenna is just a couple feet away from the System BLUE. I have a length of SFTP cable on order so I can move it to a far corner of the basement.
Jeffrey Honig
Trumansburg, NY  USA
Station: 2872
Stations: 2872
Jeffery, I would suggest you obtain a baseline using a 'normal' power source so that you have something to compare with when you add the POE, change cables and so on.
Without a base line you will be flying blind and you will not know if something got worse or improved.
Dries
I have dozens of USB power supplies. Given the cool graphs from the controller I'll have to do a comparison.
All I need is time...
Jeffrey Honig
Trumansburg, NY  USA
Station: 2872
Stations: 2872
probably, you can add a small stabilized DC-DC bost converter between poe-splitter and blue system..
[Image: 4178719.png]2855
Stations: 2855
I've ordered a POE Texas splitter to try to compare.
Jeffrey Honig
Trumansburg, NY  USA
Station: 2872
Stations: 2872
  PoE recommendations for System Blue bodgit 9 78,471 2016-10-08, 18:03
Last Post: allsorts
  How to PoE Red Controller chubros 7 60,234 2015-04-06, 13:59
