how accurate is this ntp
Hi Ross
that's interesting. many thanks for your reply.
if i calculate the average of your stratum 3 server's offset ( 0.114 ms ) it's almost identical as system red. so it fits perfect. and you are using "only" stratum 3 references. mine is not just a snapshot. i see similar values very often. my system red has an offset for about +7 ms. i have to write a script which calculates the average of hundreds of values out of the peerstats file. but i am sure this will bring a similar result. no idea why this behaves in that way.
which version are you running. i have
FirmwareRev. 7.4 / Aug 17 2014 16:41:16
HardwareRev. 10.4 (PCB-Id 2)
BTW: where did you configure the last line in the posting where your stations are listed ?
// hans
how accurate is this ntp - by hans - 2015-02-17, 21:24
RE: how accurate is this ntp - by Tobi - 2015-02-19, 21:57
RE: how accurate is this ntp - by hans - 2015-02-22, 16:30
RE: how accurate is this ntp - by hans - 2015-02-23, 22:23
RE: how accurate is this ntp - by hans - 2015-02-27, 05:51
RE: how accurate is this ntp - by Tobi - 2015-02-27, 19:11
RE: how accurate is this ntp - by hans - 2015-03-02, 20:06
RE: how accurate is this ntp - by Tobi - 2015-03-03, 10:04
RE: how accurate is this ntp - by Knickohr - 2015-03-12, 11:41
RE: how accurate is this ntp - by hans.mayer - 2015-03-15, 21:10
  How Accurate? cutty 0 7,694 2016-08-28, 20:49
