Threads: 15
Hello to everyone. I just completed my red h-field kit and i had some questions.
1) I had 2 ferrite rod 200mm antennas. Should i cut their cables and solder them to new thickest ones??
2)Do i need any special settings in the controller? I have it in automatic mode.
Thanks in advance..
Threads: 15
I just wondering because even i had a lot o signals i see the stroke number to 0. Anyone to help me?
Threads: 55
Hi Chubros
If you're showing signals, the wires are probably ok. Let's do nothing, yet.
What is your station number?
Threads: 15
2015-02-24, 20:31
(This post was last modified: 2015-02-24, 20:47 by chubros.)
Thanks for your reply. My station number is 1300. I have strokes detected but i see that the gain drops many times. Do you have any clue???
Forgot to say that i tried to different positions and different cables between controller and amplifier. Now i had a shielded cat5e 7m cable. Gain drops to 4*1*40 and goes max 10*1*40only in channel 5. Antennas soldered to board.
