New Installation
Dear all,
during he new installtion of my page I always get the message:
"Error:
at
INSERT IGNORE INTO bo_user SET id=1, login='', password='', level=1, mail=''
Some errors occured! Please check if the tables exists."
Can someone give me a hint, I checked all setting in config.php an I have absolutley no idea what the origin of this message is.
Kind regards
Thomas
did you create the database ?
(2015-05-17, 08:50)Eric.Wouters Wrote: did you create the database ?
Eric,
thank you for your reply. Something happend... but still 1022.64 of 1024 MB are free.
But I doubt the the complete database is so small   Sad
Best regards
Thomas
an empty database (with tables pre configured) isn't big at all
but guess something is wrong
since this is a new install, just kill it and make a new one. Nothing you loose.
be sure to use the correct details in config file to connect to database. Some hosters user prefix in names (cpanel for exemple uses accountname_dbname etc)
(2015-05-17, 09:14)Eric.Wouters Wrote: an empty database (with tables pre configured) isn't big at all
Eric,
I deleted the database and started again. It seems that I got one step further. But I get the following report:
Strict Standards: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead in /homepages/8/d482373604/htdocs/Blitz/includes/templates_gmap.inc.php on line 164
Strict Standards: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead in /homepages/8/d482373604/htdocs/Blitz/includes/templates_gmap.inc.php on line 165
Strict Standards: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead in /homepages/8/d482373604/htdocs/Blitz/includes/templates_gmap.inc.php on line 172
Strict Standards: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead in /homepages/8/d482373604/htdocs/Blitz/includes/templates_gmap.inc.php on line 180
Strict Standards: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead in /homepages/8/d482373604/htdocs/Blitz/includes/templates.inc.php on line 520
2015-05-17 11:52:12 + 0ms | 2015-05-17 11:52:12 + 0ms | ***** Getting lightning data from blitzortung.org ***** 2015-05-17 11:52:12 + 0ms | 2015-05-17 11:52:12 + 14ms | Information: PHP Execution timeout is 50000s --> Fine Smile *** Setting MyBlitzortung timeout to: 55s 2015-05-17 11:52:12 + 16ms | Waiting 20 seconds, to avoid too high load on Blitzortung servers ... 2015-05-17 11:52:12 +20018ms | 2015-05-17 11:52:12 +20018ms | === Strikes === 2015-05-17 11:52:12 +20050ms | Last strike: 2015-05-17 11:49:14 *** Loading 2 files from 2015-05-17 11:40:00 to 2015-05-17 11:50:00 *** This is update #5 2015-05-17 11:52:12 +20145ms | Downloading file /2015/05/17/11/40.log, last modified 2015-05-17 11:44:12, last position 92414 bytes: OK 2015-05-17 11:52:12 +20148ms | Found latest strike from last import 2015-05-17 11:52:12 +20314ms | Downloading file /2015/05/17/11/50.log: OK 2015-05-17 11:52:12 +20599ms | Lines: 274 *** Size: 132kB *** New Strikes: 80 2015-05-17 11:52:12 +20656ms | 2015-05-17 11:52:12 +20656ms | === Stations === 2015-05-17 11:52:12 +20769ms | Last update: 2015-05-17 11:37:38 *** This is update #1 2015-05-17 11:52:12 +22014ms | Stations: 1065 *** New Stations: 0 *** Updated: 616 *** No Update: 450 2015-05-17 11:52:12 +22089ms | 2015-05-17 11:52:12 +22089ms | === Raw-Data === 2015-05-17 11:52:12 +22089ms | Not implemented! 2015-05-17 11:52:12 +22093ms | 2015-05-17 11:52:12 +22093ms | === Strike alerts === 2015-05-17 11:52:12 +22097ms | No alerts sent. 2015-05-17 11:52:12 +22104ms | 2015-05-17 11:52:12 +22104ms | Import finished. Exiting... 2015-05-17 11:52:12 +22104ms |
I wonder why the scripts complains about the time setting ... ??? Time setting in config.php is UTC.
Kind regards
Thomas
mmm not to sure but feels like server time is offset to what is needed by the script though I'm not a coder
maybe a coder can give more details
but at least your database is working and it did loads data  Smile
in my config I set as follows
//Your timezone
define("BO_TIMEZONE", "Europe/Paris");
(2015-05-17, 12:02)Eric.Wouters Wrote: mmm not to sure but feels like server time is offset to what is needed by the script though I'm not a coder
//Your timezone
Dear Eric,
tried to change it to Europe/Paris. The the system complained it needs "Europe/Berlin"....  Huh
In the moment I give up....maybe I give it another try tomorrow.
73
Thomas
I have the same problem- do have someone an idea ?  Thank you !
Stations: 2107
  Request for historical data › sound art installation, Nuit Blanche Paris 2026 aker 9 3,404 2026-06-29, 13:59
Last Post: aker
