2015-07-04, 08:52
The Europe view on lightningmaps.org doesn't show any strikes if zoomed in. You used to be able to do this fine. Does anyone know a fix?
Lightningmaps.org history zoom
2015-07-04, 08:52
It appears to be working as designed... perhaps it may be your 'display' time settings on the page... for example, if you only have "2-24 hours' ticked, and
there were no strikes within that 'zoomed' area within the last 2 hours, there'll be no strike display. Likewise, if only "0-15minutes" is ticked, strikes older than 15 minutes will not be displayed... or if only "15 minutes -120 minutes" is ticked, "only strikes between 15 minutes and 2 hours of age" will display, not <15 or >120 etc... in combinations, etc. to see all strikes from "now (0 minutes) to last 24 hours, check all, and suggest check auto update also. Cheers! Mike
When zoomed out there are loads of strikes but they disapear when I zoom in, even though when zoomed out it says there are strikes in that area.
*Edit: It's Working Now |
« Next Oldest | Next Newest »
| Request to correct the position of station on the map www.lightningmaps.org | Station_Roko | 1 | 11,825 |
2025-07-02, 16:46 Last Post: Asbjorn.Aamot |
| station 3021 in https://www.lightningmaps.org | jeanse | 1 | 17,333 |
2024-08-20, 05:11 Last Post: gerbold |
| LightningMaps.org - Blue Dot in Wrong Place | GlenVision | 4 | 22,601 |
2024-08-07, 17:02 Last Post: mendip_defender |
| Problem with lightningmaps.org | JungMich | 3 | 21,166 |
2024-07-06, 17:17 Last Post: gerbold |
| lightningmaps.org/realtime | Blubbel | 0 | 15,287 |
2024-07-01, 07:29 Last Post: Blubbel |
