Go to the status page of your controller, make a note of the "Device ID:" under "Controller / CPU". Log into the forums or remain so, go to the site login page top right and enter your existing user name into the "New Username" field and the code found above into the box marked "Register Code". This will create a site user, register your controller and connect your forum username with site username.
Once logged into the site you can update the information about your set up, aerial type(s), which channel has what aerial etc. On the site Input 0 is Ch1A, Input 1 Ch1B etc and dimensions are in mm.
System Blue Order - by anselking - 2016-06-07, 11:45
System Blue Order - by anselking - 2016-06-07, 11:49
RE: System Blue Order Status 12. August 2016 - by allsorts - 2016-10-23, 16:27
RE: System Blue Order - by readbueno - 2017-07-28, 22:04
RE: System Blue Order - by robo - 2017-07-29, 00:07
RE: System Blue Order - by readbueno - 2017-07-29, 06:41
RE: System Blue Order - by readbueno - 2017-07-29, 17:12
Contact station owner? - by TAGood827 - 2017-08-03, 13:20
RE: Contact station owner? - by BobW - 2017-08-05, 15:26
Proposed Station Location - by geofabryka - 2019-06-20, 19:25
RE: Proposed Station Location - by dupreezd - 2019-06-20, 21:40
  How to order system blue-basic? Kellogs 3 15,992 2025-04-20, 00:09
Last Post: DrFX
  Does the System Blue Basic take the same Firmware as System Blue? DrFX 3 16,523 2025-04-19, 23:25
Last Post: DrFX
  Can I order? larryf 1 15,852 2024-09-07, 20:55
Last Post: gerbold
  System Blue order status (10.3.2020) Egon 33 231,669 2023-11-29, 21:57
  Issue starting Sunday August 1st at 13.00 PA4EME 2 24,676 2021-08-07, 23:08
Last Post: orion_jb2001
