Using the on/off switch with the new Blue enclosure
The switch is just to the left of pins 5,6 when looking from the front, note pin 1 marking on the board. Pins 5,6 are the ones you should remove the jumper from and plug in the pig tail.
Pins 1,2 and 3,4 are for voltage selection of the E field amp and the jumper should be left on pins 1,2.
DelandeC is correct.
RE: Using the on/off switch with the new Blue enclosure - by kevinmcc - 2016-11-13, 12:36
  System Blue Basic - Indicator Panel for Enclosure? DrFX 13 8,988 2025-07-05, 15:30
  Brackets for system blue enclosure petterfs 0 8,910 2020-04-17, 18:37
Last Post: petterfs
Photo Need clear plastic hard drive box as enclosure mwaters 0 9,938 2019-06-27, 23:29
Last Post: mwaters
  System Blue - Rocker Switch Question chevyman142000 5 33,246 2016-09-09, 16:57
Last Post: chevyman142000
