PCB 19.3 Coil whine?
What is the current rating of the USB power supply? Did you populate through-hole LEDs? That will increase the current draw.
Your first USB supply sounds like it was overloaded if it can only provide 4V.
Coils can make noise if the wire is a little loose and is excited at the resonant frequency. A poor power supply might be running in a mode that would result in a lot of noise. This could be audible in the coils. I would look for a cleaner USB supply with higher current capability. If a friend has an oscilloscope you could observe the output and check for electrical noise that could be causing the acoustic noise from the coils.
Greg
Stations: 706, 1682
PCB 19.3 Coil whine? - by Polyphemus - 2016-12-02, 17:03
RE: PCB 19.3 Coil whine? - by elythomaslumber - 2016-12-04, 10:31
RE: PCB 19.3 Coil whine? - by Polyphemus - 2016-12-07, 14:30
RE: PCB 19.3 Coil whine? - by HamelGre - 2016-12-07, 21:02
RE: PCB 19.3 Coil whine? - by Polyphemus - 2016-12-08, 15:47
  Ethernet speed connection 10/100 on PCB 19.5 lyova 6 30,796 2020-03-07, 22:12
Last Post: mwaters
  System Blue PCB 19.4 vs 20.6 dhitzigrath 6 40,031 2019-11-22, 04:48
Last Post: kevinmcc
  PCB 19.5 toutoumeteo 4 24,380 2019-06-02, 19:36
Last Post: Egon
