2017-03-05, 20:40
Good evening, I contact you because I want to know what is the minimum distance between the antennas H and F.
Thanks in advance.
Greetings
Francesco
Thanks in advance.
Greetings
Francesco
Stations: 1583
Minimum distance between H and F antennas
2017-03-05, 20:40
Thanks in advance. Greetings Francesco
Stations: 1583
2017-03-05, 21:23
(2017-03-05, 20:40)ohifra Wrote: Good evening, I contact you because I want to know what is the minimum distance between the antennas H and F. The E probe should be outside, ,pimted verticaly, at leat a half-meter away from any metal pole mount... as far from any noise sources, buildings, and obstacles as possible,at least two-three meters above ground, and not grounded to anything... other than that, put your H anywhere away from noise sources.
2017-03-09, 04:17
(2017-03-05, 21:23)Cutty Wrote:(2017-03-05, 20:40)ohifra Wrote: Good evening, I contact you because I want to know what is the minimum distance between the antennas H and F.
Stations: 1583
« Next Oldest | Next Newest »
| seeing map strikes and counting seconds for distance | GeezerD | 0 | 16,098 |
2025-09-06, 22:14 Last Post: GeezerD |
