I absolutely love your site and what you are doing. It provides useful statistics and information to whoever needs them.
I have one question. Is it at all possible to know the elevation of the lightning impacts? I can use the satellite map to infer whether the impact has hit ~ sea level or a hill but I have no way of estimating the height of the impact point. Is there a way you could calculate this or even estimate (with reasonable accuracy) from the topography of the map?
EDIT: Nevermind, I just found out that if you zoom in enough and switch to ''map'' and enable terrain, you see contour lines.
